To anyone looking to acquire commercial radio programming software:
Yes the XTS series can do conventional, trunking both type I, Type II, Hybrids, and 3600 KBPS Digital Trunking. They come in VHF Hi, UHF, 800/900 MHz, and the XTS5000 I believe also can do 700 MHz, and does 9600 KBPS ASTRO 25 digital trunking, and conventional digital.
Didn't know any of those were still around,.. weren't they discontinued like wayyy back? But in that case,... yes the STX series did do trunking, I believe type I, II, and Hybrid analog only?????? They could also do Conventional, not sure how many chans.
Baltimore Co. FD up until 3 years ago used STX radios. Then they slowly started to phase them out. Now the whole County exept for the eastside uses MTS 2000s. But now the County is phasing in XTS 5000s. So we have the old radios. The old new radios. And the new new radios. If this sounds confusing to you, it does to all the FFs on the street to.
If you are inquiring about the STX the later models where the 821 series with 1.0, 1.1 etc GPL or GPS controllers. They could do a total combination of 96-98 systems or conventional channels. That is not a misprint...90+ systems at 16 talkgroups to a system. Also depending on the version could do mutli-pl, repeat-direct etc. Some of the middle series such as the REL versions had a MODE option... now the downside. These units unless you have the smaller battery are bricks. They are old having been discontinued back in the 90s. They cannot scan conventional and they only scan 5-6 talkgroups per system. Also many of these units cannot follow a mixed / narrow control channel scheme. On the plus side old or not, they where built, they are readily available today.The later versions did Type II, TYPE i and conventional while earlier versions did Type 1 and conventional. The controller board version is the most important thing to have.
In Harris County, Texas Pct.4 still uses STX's for our Type II system. I don't know why, I'm sure they have the money to at least get MTX 8000 B7 models.
