Motorola Sytem ID
tolley
Hurlock, MD
How are Motorola System ID's determined? I checked the Motorola Information section and there did not seem to be anything pertinent there. :)
loumaag
Silent Key - Aug 2014
Katy, TX
If you are talking about the system ID's as published here on the site, they come from running Trunker, T4Win, or in the case of APCO-25 reading it from the screen of the scanner (or one of the newer programs available to take the data dump from the Pro-96.) The Pro-96 will also give you a 3600baud CC ID in manual mode on the screen. Not sure about the Uniden models.
BANDIT
Gainesville, Ga
I think I have read somewhere that the sys id's are assigned by the tech's setting up the system. Its used to id the system from others in the area. Here in Ga. the Georgia State system and the Univ of Ga have the same sys id, but due to the locations of both systems there is no interference with each other.
scannerfreak
Well Known Member
Indiana
Hmmm, I thought they were assigned by Motorola....
N4DES
Retired 0598 Czar ÆS Ø
South FL
The System ID is assigned in Schaumburg when the system is interconnected and programmed at the factory. It's not done in the field.
