n1das
I wanted to share an easy mod for the Motorola Talkabout T800 and related Talkabout models to enable charging AA NiMH batteries in the radio instead of using the stock 1300 mAh NiMH pack. Using 2300 mAh or 2500 mAh NiMH AA batteries roughly doubles the operating time on a charge. The mod disables detection of AA Alkaline batteries so the battery charger is always enabled and can charge AA NiMH batteries. The mod is VERY simple: Open radio, clip one wire to the battery tray, and reassemble radio.
The Motorola Talkabouts detect the battery type by looking for a voltage present at one of the terminals between two AA cells in the string of 3 AAs to determine what batteries are being used. The stock 1300 mAh NiMH pack has 2 terminals, one at each end and doesn't contact the middle terminals in the tray so no voltage is detected there. When AA Alkaline or AA NiMH batteries are used, a voltage is present at the middle terminals and the battery charger is disabled. The purpose of detecting the battery type is to ensure the battery charger is disabled when AA Alkaline batteries are used. When the radio detects AA batteries are being used, it may also set the operating voltage range for Alkaline batteries instead of NiMH batteries but this is unconfirmed. It doesn't matter in this case because disabling detection of AA batteries so the charger will operate sets the battery type to NiMH, which is what we want.
To open the radio, remove 7 small Phillips head screws. You'll need a small precision screwdriver for this. CAREFULLY lift the battery tray out of the radio, taking note of the LED & vibrate motor cable at the top and the battery tray cable at the bottom.
Cut the YELLOW wire to the battery tray as shown below. This wire connects to one of the middle terminals between 2 AA cells in the string of 3 AAs in the battery tray. This disables detection of the battery type. The battery charger will always be enabled for charging AA NiMH batteries. Charging the stock 1300 mAh NiMH pack is unchanged.
The last step is to carefully reassemble the radio. Note there is an O-ring gasket around the battery tray for a weatherproof seal. Make sure the O-ring gasket is seated correctly during reassembly. When I did the mod, the gasket stuck to the battery tray when I first opened the radio and then it fell out. I found it easiest to install the gasket in the groove in the case of the radio instead of in the mating groove around the edge of the battery tray.
A few things to note:
I found the Motorola Talkabout T800 already has good battery life on a charge with the stock 1300 mAh NiMH pack when used according to a 5/5/90 duty cycle. It seems to have excellent standby time when not scanning and not hearing any activity on a channel.
I'm in the middle of testing battery life on a charge with 2300 mAh AA NiMH batteries so it will be a while before I have some numbers to report.
- This mod is completely reversible if desired by simply reconnecting the yellow wire that was cut to the middle terminal on the battery tray.
- Be careful to avoid charging AA Alkaline batteries in the radio by accident since the battery charger is always enabled regardless of battery type.
- Charging time for a full charge with 2300 mAh or 2500 mAh NiMH batteries will be roughly double the charging time required for a full charge with the stock 1300 mAh NiMH pack. The time for a full charge with 2300 mAh or 2500 mAh NiMH batteries will be around 30 hours. It's not a big deal if the radio tends to be left connected to the charger all the time when not in use. The benefits are the operating time on a charge is approximately double that of the stock 1300 mAh NiMH pack.
- Charging with the stock 1300 mAh NiMH battery pack is unaffected.
