Motorola TRBO using XPR6350
Pointerman
Anyone else having this issue? I have a MotoTRBO system at my workplace. Have had a few of the XPR6350 exhibitiing the same issue. While monitoring a radio channel, you can hear some other units that are on the channel but at times you will not hear a response. If this was on a talk around channel not going through the repeaters, I could see this happening but this has occured on channels that run through the repeaters. Had a motorola vendor service technician on site and we re-layed the talk group programming on the unit and that corrected this issue.
Does anyone know if this is a common occurance? Is there a firmware upgrade that is available to fix this? I have over 100 units on this system and do not want to have to chase this around from unit to unit.
Andy
JRayfield
Springfield, MO
What version is the firmware in your units?
John Rayfield, Jr. - CETma
Rayfield Communications
Andy
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
want to make a second request for your firmware versions (portable and repeater). If it is not a rf issue (co-channel/adjacent channle inteterference) then it sounds like firmware or scan. Would you be willing to share the codeplug to find out what the tech did to fix it? Thank you, TT.
