Motorola Trunked System Wild Cards
josephdavis13
Austin Texas
I want to program Motorola Trunked systems with wild cards to find other talk groups for the following trunked systems:
Motorola APCO 25
Motorola Smart Net Type 2
Joseph
K9GTJ
Kokomo, IN
What is you system? On my 996T, you select ID Scan which will only follow talkgroup IDs I have pre defined or ID Search which will find any talkgroup IDs being used.
DaveIN
Founders Curmudgen
West Michigan
Just use ID Search to find unknown ID's. If your Uniden TrunkTracker uses alphatags and the radio stops on the talkgroup not tagged, then you can press enter to save it to memory and go back later and identify it by programming it with an alpha tag.
blueline_308
Eastern, NC
What I would like to be able to do is this...Instead of having to program a seperate alpha tag for each ID, program a wildcard, say 48* and have all ID's that start with 48 be assigned the tag POLICE...kinda like i0 for I-Calls. This way ID 48000, 48016, 48017, etc. would all be assigned POLICE tag.
DaveIN
Founders Curmudgen
West Michigan
You can do that for EDACS systems using the AFS wildcards, but not Motorola talkgroups.
