Motorola Turbo Capacity Plus
RoninJoliet
ILL
The local hospital has gone to a single frequency Motorola Turbo Capacity Plus, i programmed it into my 996P2, i hear them once in a great while and UID and TG fine but before this they were very active, this system being voice and data can they communicate via data eliminating most voice ,….TY
KevinC
The big K
Super Moderator
1 point
Do you have a question about how Cap+ works? If not then I’m moving this to the Illinois forum.
FFPM571
Nashvillle
Cap+ has more than one frequency at minimum 2 and voice channels are voice Data are data . You are getting a Mototrbo repeater with 2 time slots confused with a Cap + system
R8000
Very Low Battery
I built many single repeater Capacity Plus trunked systems. They were a perfect fit for small operations that wanted a true system wide "all call".
In fact, several of them are in the RR DB incorrectly as conventional systems.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
As R8000 stated, this is not correct. A Cap+ system can have only one repeater and voice /data can be mixed on the same timeslot.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Feel free to submit correct information. This is after all a user-driven site.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
Please submit the corrections so things can be updated in the database!!!
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
I have also installed dozens and dozens of them for the above reasons. Each repeater is 2 slots, so a single repeater has 2 "channels" (a 2 channel trunking system if you will). If you add a second repeater, now you have 4 available slots. All the way up to 8 repeaters, which is 16 slots and can handle hundreds of talkgroups very easily. TT
alcahuete
Antelope Acres, California
Why is this puzzling? One repeater, two timeslots. One frequency can handle trunking / voice / data all on one frequency for a small company.
I see what he is saying now. I thought he was saying that Cap+ can only have one repeater, which would be incorrect. But I see what he's getting at now.
RoninJoliet
ILL
So I wrote the original question about this hospital system, talking to one of the security he says there using a system thru there cell phones with earbuds except in tough areas where they use digital voice radios ,....Sounds like possible LTE ??
Frmn85
Could also be CTI radio GW with smartphone app- a computer running a speacial software connected to a mobile radio to call out to smarphones running a special app via the internet.
RoninJoliet
ILL
Thank You for your suggestions, there talking more using one frequency and seem to use only one TG 135, and seem to have about 10 UIDs assigned for each security guard in the i60xx range and seems to only stop on "Slot 2,....
dave3825
Suffolk County NY
Not familiar with the 996p2, but a radio will only have 1 uid (radio id)) Is it possible you are seeing private calls between sec guards?
RoninJoliet
ILL
Yes one TG 135 and i guess there private calls as they come up as i6047 etc
werinshades
Chicago , IL
The small i (eye) on the 996P2 indicates a radio ID. In later model scanners, the small i was eliminated to document radio ID's (x36hp/SDS series). I don't remember how private calls were displayed on the older model scanners.
