Motorola Type 1 Fleet Call
pboy
How do Motorola Type 1 fleet calls work ?
I monitor dispatch of a public utility system on subfleet 000-1.
Both base and mobiles are heard on that same subfleet.
From time to time things switch to 000-0 subfleet.
I hear only the base station side of the conversation on 000-0.
The responding mobile is heard on 000-1.
Is this normal behavior for the all-call function? Assuming dispatchers are activating it for some unknown reason.
Scanner is BC780XLT.
DaveH
Ottawa, Ont.
I think that is the way it works. The dispatcher calls on the -0 subfleet, which all the other subfleets can hear, but they can't hear each other. One mixed system local to me was doing that with 3 subfleets, but they seem to have converted to Type II groups. Now they can use "multi-select".
Dave
pboy
Thanks Dave.
I have never heard a 0 subfleet used before and wasn't sure how it worked.
Didn't know if it is just a "one-sided" announcement or supposed to be a patch of the two subfleets together.
D
DaveNF2G
Guest
A "Subfleet 0" announcement is as described by DaveH, and will only be heard on one of the system repeaters. A Type I patch transmission can be heard on each of the subfleets that is included in the patch, and will be heard on as many system repeaters as there are subfleets in the patch.
pboy
And thank you DaveNF2G.
To further clarify.
When dispatch "announces" on subfleet 0, it is the only user of subfleet 0.
Listening subfleets would not switch to it to talk back to dispatch.
DaveH
Ottawa, Ont.
Yeah, for a while this bugged the heck out of me. Playing with Type I block sizes, trying to get the sizecode right, often -0 subfleets would come up when they should not have. In this case myself and another guy tried just about every sizecode, but nothing would get rid of the -0. Eventually, after watching on Trunker and listening at the same time, it became obvious what was going on.
Dave
pboy
I knew I had a good map. B0-S14.
It always worked and made sense since the power company was sole user of the system and really only needs 1 fleet at this site.
Only 3 or 4 of the 15 subfleets are ever used.
Of course, no way would there be the resultant number of users.
It was just out of nowhere that this 000-0 stuff started popping up.
Another weird thing I have noticed on this system.
A random private call radio id (7xxxxxx) "blips" up. Never really locks on to a radio to radio call. Paging?
