Motorola Type II SmartZone #2 -Unitrunker
Bear15
In order to setup Unitrunker with Motorola Type II SmartZone #2, something does not add-up or can't find the Custom Frequency Tables
for Lo/Hi Unitrunker.
I have looked throughout the RR database and forums and was not able to find any relevant material that would help me calculate the band plan for zone #2.
Base Spacing Offset
141.01500 15.0 380
151.73000 15.0 579
154.32000 15.0 632
mciupa
Canadian DB Admin
Moderator
Hope you enjoy math.
The wiki has this guideline in which you will have to replace with your Base, Spacing, and Offset numbers. (Top of this article)
Otherwise, maybe someone with Freescan which has the built in calculator can bail you out ( It did have it when I owned a 396XT and 996P2)
Bear15
Actually, there was two issue with my trial-post of Unitrunker, first one the LO/HI has to contain the same offset value marked in RR.
And the second one, version 1.x version of Unitrunker is old and obsolete now. Use version 2.x beta, but won't see it on their public page,
you must join their google group to D/L, and version doesn't need DSD+FL to P25.
