Motorola Type ll smartzone
APX8000
Sarcastic Member
AES-256 secured
G5 does not monitor SmartZone systems, only P25 trunked. The only work around is to conventionally monitor it but not ideal.
APX8000
Sarcastic Member
AES-256 secured
You program each frequency as a conventional channel and then set a knob position to scan all them. Again, not ideal as you basically are wasting multiple channels per zone and you cannot select a talkgroup...you basically have to listen to every transmission that comes over the frequency and use scan to follow channel grants. I don’t recommend it.
TxScanner
we have a local PD that uses that, be nice to listen too. Could this be added later?
MTS2000des
doubtful. While old and crusty, Smartzone/Smartnet uses proprietary protocols. Yes, Uniden and others have figured it out, but it, like EDACS, is being killed off and long off support. Those who have such systems alive, I pity them (been that guy, know what it's like with your MTC3600 on hospice care and MSF5000's with crackly VCO modules...).
WX4JCW
All Over USA
The only Smartnet/Smartzone one I really listen to is Memphis, its Smartzone/Smartnet but most of the voice is P25, but I hear it's going away soon
maus92
Annapolis
Unication has no plans to license the SmartNet / SmartZone protocol from Motorola. I spoke to a Unication rep at APCO, and he made it clear that the company does not want to invest in an obsolete technology even though a (shrinking) market exists.
trido
RETIRED
Southern In
wonder if pager would scan over or lock onto a cc scanning conventional?
maus92
Annapolis
I'd imagine it would open squelch on an active control channel, thus you should not program the primary control channel. Might be a PITA on a SmartNet system that regularly rotates cch's, but SmartZone *generally* stays on the primary unless there is an issue, then goes back to the primary when the issue has been resolved.
boatbod
Talbot Co, MD
There's ways to (inexpensively) receive Smartzone, but you'll either need an older digital trunking scanner or a couple of RTL dongles and one of the SDR apps that understands that protocol. On Linux (RPi) that would be be TrunkRecorder or OP25, and on Windows it's going to be Unitrunker or perhaps the (older) Trunk88
a417
the one I used to do that on rotated every night at 2300, just cleared the lockout and blocked the new one. The price one pays...
