Motorola UHF CT150 Business Radio
conve36
Menifee/Lake Elsinore, Ca
I have an older Motorola CT150 UHF business radio I would like to use with a GMRS repeater...
Link to info on this radio - http://www.aaacomm.com/motorola_ct150.htm
Would this radio work well with a repeater? Powerful enough? Any idea how close I would have to be to the repeater? (This is a 2-watt UHF)
I do not know too much about repeaters and how they work so your comments are very helpful.
Thanks!
Grog
Banned
West of Charlotte NC
Depends on the repeater as to how far away you can be. I could have 440 repeaters that are three miles away but if they are at 10' then they won't do much good. But, a repeater at 1000' will do quite a bit better.
The condition the repeater is in also effect it, feedline, antenna, etc all add up to how well a repeater works.
Astro25
Chicagoland
If it's UHF (presumably "R" split, give us the model number) then yes it'll do GMRS, FRS, etc.
At 2 watts it'll suffice if the repeater you are trying to talk to is in your town, and as Grog mentioned, at a decent height.
n1das
Nashua, NH
Height Above Average Terrain (HAAT) also makes a HUGE difference.
Grog
Banned
I should have worded it like that, I forget some idiots use their hight above sea level which only makes sense to me when you like at sea level. We have a local repeater where the trustee states it in ASL even though this area is around 800-1000' above sea level anyway. He is a typical old fart ham though.
I wonder if some repeater owners just use ASL to make their e-repeater-peen feel bigger :lol:
chrismol1
Out of Range
Here is a picture from my house, circled is where the "repeater" is. AKA Elsinore Peak. So I DO have a good line of sight, which is great right?
try it, thats the only way you will know
looks good line of sight, quite hike though, barely make out the mountain range,try it and you will see
.5 watt FRS bubbles are rated at 25 miles, and those are tested in line of sight desert, so it should work!
so a 2 watt should work
