Motorola UHF Preselector out of band rejection question
brushfire21
NorCal - Napa Valley
Question for the moto gurus or anyone else. Have an application with a UHF 460mhz repeater getting hammered / desensed by 700-750mhz cell tower that is 50'-75' ft away at the same elevation. Current duplexer isn't cutting the mustard apparently and I'm curious if a moto or similar UHF preselector would help or need look into a 700-750 band reject filter on the rx side? Have not looked at the extended band reject portion of the curve on a preselector for some time and what its like up that far. Thanks in advance!
merlin
DN32su
Perhaps the addition of a band reject filter in front of the duplexer. It will mean about another 1.5 Db loss.
rescuecomm
Travelers Rest, SC
The old Micor front ends were pretty tight, but it sounds like you need a large pass-band cavity tuned for your receive frequency. A reject cavity would help if you can identify a spur.
RFI-EMI-GUY
To answer your question it would really help to know what kind of repeater this is, details about the receiver and existing filters.
freddaniel
Newport Beach, CA
You are correct, a three to six series resonator pre-selector would resolve your problem, between the duplexer and the receiver. Something like a transmitter or receiver filter from an old Motorola radio. Even an old GE Mastr II front end would likely work. Far cheaper than a new Sinclair.
Fred
prcguy
Fred
In my experience these window filter resonators have high insertion loss on the order of 1.5 to 4dB. I think a better approach is a full size 1/4 wave cavity which has more like .5dB insertion loss and very narrow band width. These show up used in the $75 range all the time.
RFI-EMI-GUY
Filters and cavities can have spurious responses where higher frequencies can leak through, albeit with high insertion loss. The OP has not given enough specifics. Also OP has apparently left the building.
brushfire21
My apologies, for some reason I wasn't getting updates via email to know I got responses. I just snagged off fleabay a quantar UHF preselector that has 1.55db insertion loss and about 90db of rejection between 469 MHz and 750mhz from the ATT tower next door.
Not enthused with the 1.55 loss but in the big picture it's better then a deaf/over loaded front end and takes care of anything in the nearby vicinity.
This is an Icom FR4000 repeater and sadly only has a simple band reject flat pack and the owner/friend is lacking funds. Though I'm not sure how much a BpBr would help but it would be better then what's there.
As there was no other UHF equipment at this site until a few years ago, the flat pak was fine. Verizon and ATT both upgraded and added additional bands to the towers in the 700-850mhz and appears that's causing issues.
the freq pass is about 1-1.5mhz at 469 MHz and then from 30mhz to 2.1ghz is 80-90db rejection and fairly flat. Will know next week how well it does but suspect it will go along way in restoring some recieve sensitivity.
lenk911
St Paul, MN
Let me share with you the old radio engineer's rule of thumb: Generally 2/3 rds (of the db's) of the filtering to solve interference issues usually will reside in the offending transmitter, 1/3 in the offended receiver.
You need to FIRST determine whether your interference is transmitter sideband noise, receiver desense, a spur, intermodulation or an image. Just stacking filtering in your receiver circuit is not a solution. All it does it make you feel like you have accomplished something but you may have just further numbed your receiver.
Because of the frequency separation (460 verses 750 MHZ) I would first look to another transmitter 50% between the two frequencies (~605 MHZ) for potential intermod. Then look to the 25 and 75% points (i.e. 532.5 677.5) for a transmitter.
The intermod may be mixing in your radio system. Check for non-linear connections, oxidation, bi-metallic connectors, poor installation practices etc. Is your transmitter a player in the problem?
An old engineer once taught me that 80% of a radio system problem solving is done with your mind, 20% with your hands. Good luck!
