Motorola (vertex) VX 2100 select 5 problem.
E74D
Hello.
Few days ago a friend of mine asked me about his Motorola VX-2100 mobile radio, that he uses for Taxi. He told me that problem is about Select 5 signaling and that radio dont transmit signaling tone every time when he do PTT! I tried radio my self and situation is that select 5 tone can be sent only after about 1 second of pause between TX! Let me explain a bit more: 3 digit select 5 signaling code is sent at the beginning of every TX just for the PTT ID purpose. When you finish TX you have to wait about 1 second and do PTT again and only then radio will send select 5 signal again. If PTT is pressed quickly than that 1 second, it does transmit but not sending PTT ID, only "normal" carrier with MIC audio.
I have searched thru all the programing software, but could not find setings about that. There is some setings in the "select 5 common section" about pre-time but that dont solve the problem.
Maybe it can not do it diferently anyway?
Thanks.
ramal121
Lots and lots of watts
Calif Whine Country
I have zero experience with select 5 signaling so my answer may be a moot point and I will only give you a generalization.
There are many types of signaling available on modern radios and they all do different functions. One of these is PTT ID where data that indentifies the transmission goes out every time. I think this is what you are looking for.
Another function of signaling is to preform what is known as Sel Call (Selective Calling). With Sel Call you use the ID data to open up another radio to receive a call. When that happens then the channel is connected for a conversation. Back and forth takes place without anymore needs of the signaling data due to a timer that keeps the channel open for this purpose. Once the timer expires then the radios revert to a muted condition and signaling will have to be resent to contact that radio again.
In a nutshell it sounds like you are using Sel Call with a very short reset timer. To do PTT ID, the radio will have to be set up completely different.
