Motorola X9000
sgtmatt
Platteville Wi
Hi I am wondering about the x9000. I know that both the head and the box have to be programed. Is all of the programing done from the box or is their a seprate cabel and software for the head?
Matt
Tulsa
They both are programmed from the radio programming cable. Note: there are two programs one to program the radio and one to program the head. You will need a slow computer (286/386) running DOS directly not thru Windows.
DPapay
Morris County, N.J.
you may be talking about a syntor x9000, if so, our programming setup is done from the moto rib and a cable that goes between the chassis and control cable connector. there are seperate dos programs for the chassis and head.
sgtmatt
Platteville Wi
I have just purchased a windows 95 laptop with a 486 speed will that work I am talking about the syntor x9000 I think I have seen a moto tech use a windows 95 speed computer to program my dads squad radio which is the same thing
Tulsa
486 maybe, but you will need to be in DOS not windows dos, great radios good luck. Sometimes the programming cable is a bit difficult to find. Here is a link to Mike's site that can tell you what you want to know about Syntors.
http://www.onfreq.com/syntorx/
sgtmatt
Platteville Wi
Ive got everything I need to get the radio on the air, but the onlything I'm missing is the programing does anyone happen to have any for sale or know where I can find one, I've checked ebay out with no luck just thought I'd check in here as well thanks
FFPM571
Nashvillle
Good luck.. The software which you should be able to only buy from Motorola has long since discontinued.
