Great radio! You have to get an enhancement key from MOT to enable 25KHz analog mode. No cost, simple to do.
Don't worry about that. In two and a half months you can't use it anyway, so moot point.
Since the rental shop will be programming the radio for you, they will have to apply for the entitlement key so the radio can do wideband on the ham freq's, There's no expiration for that. Why not get a 4550, so you don't have to worry about that? GARY N4KVE
Sounds like he intends to use it on a TRBO ham repeater and for general ham use, which has nothing to do with narrowbanding.
Just a suggestion. The 5550 is a new radio that just came out, while the 4550 has been out for a few years, so there have been many firmware upgrades, & the bugs have been worked out. The 5550 has a bigger screen which would enhance receiving text messages, if you intend to use that feature. While I don't know anybody who has a 5550, I do know several people who upgraded their 6550 portable for the newer 7550. They wish they didn't. The 6550 uses a normal antenna with a center pin, similar to other Jedi, & XTS radios. Many people don't like to use the GPS antenna, & swap out for the Jedi/XTS antenna. On the newer 7550 radio, Motorola designed a new antenna w/o the center pin, so the user is stuck using the supplied compromise radio/GPS antenna. So far, no normal radio only antenna exists, & the MX/Saber antenna has a different thread. Also on the 7550, the volume control seems to be low for most of it's movement, & gets loud only at the end of it's movement. This could be fixed with firmware upgrades, but people are not happy with the antenna situation. My point is newer isn't always better. I bought my TRBO equipment only a few months ago, & could have bought the newest 7550/5550 radios, but I chose to buy the tried & proven 4550/6550 radios that have been around for several years. But I guess since you are renting the 5550, you can return it if you don't like it. GARY N4KVEI like the color screen on the display something new to try it out before I pay out the money for one.![]()
Thanks. Did not know that. Thanks for the tid bit. But my friend who just bought the 7550 also just got a new Mercedes, & doesn't want to put a mobile radio in it. What he does want to do is somehow connect his mobile antenna to the antenna connector on the 7550 but an adapter doesn't exist. And "M" wants big bucks for the cable adapter they sell. That new style antenna jack really sucks. However, on the 6550, a $1 sma/bnc adapter is easy to find. GARY N4KVEThe antenna on an XPR7550 is not a "GPS antenna". The GPS antenna is built into the radio. The rubber flex antenna is VHF or UHF only.
I may have missed it, but does anybody know where to get the programming software for the XPR 5550 (preferrably free or little cost)?
