Motorola XPR 5550e LCD won't come on
ASAD
Swabi
Hello,
I bought a brand new Motorola XPR 5550e in 2016. I used it for a while. It was working well. Then I put it away. I just took it out to use it. It does power on but LCD won't display anything. It receives and transmits but the screen is dead. Another problem is, computer/CPS doesn't detect the radio with its Moto cable. Does anybody know how to fix it? Or do I need a professional to look into it? Thanks.
K2NEC
Sounds like it could be a flex cable issue. Make sure the connection between the head and the brick is good. If you take a small screwdriver and pry the head from the rest of the brick you should see a white flex cable. Make sure its seated properly and not damaged in any way.
