Motorola XPR 6550
Metrofire31
Auburn-Opelika, AL
Up front, I want to make it clear that I'm not trying to get MOTOTRBO software illegally. Fact is, I have an active subscription to the MOTOTRBO CPS.
I would like to see a sample codeplug for MOTOTRBO if someone would be willing to share their XPR 6550 codeplug. The CPS is different from any MOTO CPS I've dealt with previously, am I'm fairly knowledgeable about using CPS.
Devilz311
NJ
The MotoTRBO CPS comes with a bunch of sample codeplugs pre-loaded. They were loaded into the C: > Program Files > Motorola > MotoTRBO CPS > Samples folder. If not I can send you some of the sample codeplugs.
Metrofire31
Auburn-Opelika, AL
Mototrbo
Thanks, DevilZ
Yes, I've seen those samples. I think it's becoming clear that I need to let the CPS walk me through some of the tutorials so I can learn the software. That's probably what I need most right now. Thanks for your response.
Metrofire31
Atlanta
WQIT636
Go to video
I didn't download the file, but there appears to be a file on businessonline.motorola.com that's a video tutorial for MotoTrbo programming. Too large to fit on the software disk, it says on there.
Devilz311
NJ
Oh, and if you're having trouble finding some of the features you need to program, make sure "Expert Mode" is enabled under the View drop-down menu.
Flair
Delaware
How to listen to Mototrbo from a handheld:
Is it possible to listen to the Motorola XPR 6550 on a normal scanner? The local hospital uses them and my scanner "Pro96" doesnt pick it up but will pick up most other radios.
KG4INW
Midlothian, VA
No scanner is capable of decoding TRBO, at least not yet. Will there be one? Probably but have no idea when that will happen. People have had good luck however using a scanner fed into a computer running DSD which can decode TRBO, so long as it's not encrypted. http://wiki.radioreference.com/index.php/Digital_Speech_Decoder_(software_package)
N1XDS
ÆS Ø
You'll have to have a Mototrbo type radio that it can pick Digital - DMR voice. Also you'll have to know the programming codes and most people won't give that information out.
