Motorola XPR 7550E as a monitor only radio
bradam2001
Gaithersburg, Md
Was thinking about buying a Motorola XPR 7550E to use as a DMR digital type scanner, not to talk on. I have a unication g5 with DMR but only does tir 2 and not digital.
I have a BC436Hp and not that happy with it. Could I monitor commercial systems with it or not. Thanks for the feed back.
jhsands
Texarkana, Arkansas
DMR is digital... tier 1, 2, or 3. My G5 does tier 1 and 2 fine, I do not have anything to test with Tier 3.
hakwye8518
Town of Islip, NY
digital conventional, yes as long as you know the frequency, color code, timeslot, and group id. don't bother if the system uses RAS as you would need to know the RAS key. you won't be able to monitor connect plus or I believe capacity max.
jhsands
Texarkana, Arkansas
Ask here about Connect Plus and CapacityPlus/Max ---> Unication G4/G5 Owners | Facebook
I know Uni Gx will decode RAS if you click repeater mode.
