Motorola XPR6550 Programming software
WX4JCW
Stow, Ohio
it's not expensive in relative terms, and you get the firmware as well, I haven't seen the need to update to the latest though
and depending on what you want to use it for you may need to watch a presentation to get certain band features enabled, Motorola was actually very good to work with
gigaflex
Awesome thank you for your help.
K9RPL
Western Burb's of Chicago
If you're going to want to program Analog channels for Amateur frequencies you *will* need the 25KHz Entitlement. Good news is it's free. Bad news is it's a royal PITA to get. Patience is called for. There are several sites that have info on the process including here on RR.
Important Tip: When you finally get the approval to order, don't order just one. Order several.
pyro424
Is the updated firmware for the 6500 the same for the 4500?
romanr
Central TN
The mobiles and the portables use different firmware files (although the revision levels are often the same).
All MotoTRBO radios use the same CPS software.
