Motorola XPR7550E not programming
blhar15
Waterloo, IA
I just got a couple of XPR7550E VHF radios. I was able to program one with no issues, but the second one does not take the program. I get no errors from the CPS and says write was succesful, but when you go to the radio nothing comes up and it just says Searching Multi Group. If I read from the radio it actually brings back my program info, but nothings is physically on the radio. I have updated to the most recent firmware and using CPS 2.0
Thank you
K2NEC
5F6
I believe I had this problem (or a similar one), try to write a blank codeplug into the radio. This should fix the issue, then write your 7550e codeplug that you have already made and it should take.
I'm not sure why it happens and maybe someone else here can help solve the mystery.
blhar15
Waterloo, IA
I was able to successfully recover the device and it did go back to the default codeplug, however when I tried to put my custom one back in it did the same thing. Anyway have any other ideas?
Tech21
If the radios don't have the same feature set, the codeplug won't take. Best bet would be to just build a new codeplug.
