Motorola xtl 5000 programming
LCT123
I am trying to program a xtl 5000 to work with two remote heads. I checked the box for "Multi Control heads" and listed the number of control heads as two. When I power up the radio I get a "Channel ID# error. I have both control heads pugged into the radio unit but I have seen a post about "Daisy chaining" the heads together. Tried it both ways, same result. Not sure if I have it hooked up wrong or a programming issued or both.
LCT123
I don’t remember the process but you need to change the ID on one CH if I remember correctly as they are both set to 1 right now more than likely.
Not following you on change the ID on one channel. Do you mean the personality name or number?
LCT123
Also after programming, If only one control head is plugged up I get a "Missing Channel" in the lighted display. When you plug the second head up, both displays go dark and show the channel # err code.
KevinC
The big K
Super Moderator
I'm everywhere Focker!
No, the control heads have an ID number. I “believe” you press the leftmost and emergency button and while holding them press power. Change the ID via the mode knob. This is from memory though.
LCT123
Ok ill try that. I have reprogrammed the emergency button to DIR, I don't guess this should matter.
LCT123
I did read that in the CPS Help files and it refers to a DEK with the F/R buttons which I do not have. I have a old DEK Box from a spectra 9000 but I don't have the proper wiring.
ramal121
Lots and lots of watts
Calif Whine Country
No, you're confusing CH (control head) as channel. As KevinC said, press leftmost menu key and orange button as you power up. Set head to 2. When you restart the gears will grind for a bit then reboot and you will be good.
