Motorola XTL5000 Cables
CadetAnderson
Cleveland, Texas
I just picked this unit up to put into my patrol vehicle, I am looking for the cable to connect it all together. I have the power cables, I just need to know what cable is needed to mate them together and where I can get one. Any help would be appreciated.
mikegilbert
MHz so good
Los Angeles
Do you have a speaker and power cable for the control head as well? If you only need the remote mount cable:
  • HKN6170B control head data cable (10')
  • HKN6169B (17')
CadetAnderson
Cleveland, Texas
  • HKN6169B (17')
Yes I have the speaker and the power cables for both the head and the base portion. So it goes to the 10 pin connector on the base unit and the 9 pin on the head unit? I had ordered a HKN6168B so I’m guessing that is the wrong one
KE4ZNR
Radio Geek
Forgive my ignorance but what does TIB stand for? Is there a way to convert it to the other configuration?
TIB=Transceiver Interconnect/Interface Board (I have heard it said both ways).
On your second pic you see those 2 wide connectors on either side of the round connector?
They are not designed to work with the control head you have.
This is what the brick should look like connector wise:
This is what is called an "O5" TIB head that will work with your O5 Control head when they are connected up with the cables someone earlier referenced.
CadetAnderson
Cleveland, Texas
Gotcha, so I should just say screw it and try to find the correct brick instead of messing with it then.
clbsquared
Isle of Wight County
It depends on what band the radio is. If it’s just the TIB that you need, and it’s VHF or UHF, you should consider buying a 700/800 band brick with the correct TIB. ( as these are much much cheaper) The only issue you’re going to run into is making sure you program the radio for the O5 head BEFORE you do the hardware swap. You’ll need a rear accessory programming cable to do that.
