Motorola XTL5000 Mic Keyup Tone
emtanwar
Hey all,
Was wondering does anyone know how to activate the Long Beep PTT Mic Keyup Tone for a Motorola XTL5000? Software I'm using is Astro25 Mobile R20.01.00 CPS Programming Software.
Any help would be much appreciated!
Giddyuptd
Here and there
Pre mdc with pre ptt tone?
If that's what you're referring to in the mdc personality select pre with long sidetone in the mdc conventional tab, over the post mdc.
There is short tone and long tone in the mdc configuration which keeps user from talking too soon.
emtanwar
Ideally yes or something similar to that. As long as I essentially am able to get a long sidetone with the mic click. Unfortunately I wasn't
able to find the MDC conventional tab. If you could give me a lead on how I could access this that would be great! I did attach a screenshot of my tree view if that helps.
brndnstffrd
CT
Its under MDC System
You want to check Leading PTT-ID, along with either PTT ID Sidetone or PTT ID Short Sidetone. And then under the Conventional Personality menu make sure that under the Signalling tab you select MDC as the signalling type.
