I have a few questions about the programming CPS for Motorola XTS 1500. Our department recently purchased the XTS 1500's. I have the correct programming cable which is a 9 pin serial port. When i launch the cps and click read radio i get an error that says NEXTgen 10, open radio failed with a bunch of numbers. I went under user settings and made sure it was set to COM port 1 and also went under the Com port settings and changed it to COM port 1. I am also including some pictures of the errors i am getting. Is there a reason for this?
Thank you.
Thank you.
