Hello,
I am new to all this radio stuff and I am looking for someone to program about 25 XTS radios for me to use. I would like them to just have Channels 1-10. The radios are 700/800 P25. Please let me know if you can help or can point me in the direction to get it done.
Thank you,
Jonesy
Some good advice above.
Are you/your agency licensed for these 10 channels?
There are no 'free', itinerant, Part 95 or amateur radio channels in the 700/800MHz band. Unless you have a valid FCC license for these frequencies, it would be a violation of the FCC rules.
If you are covered under a valid Part 90 license, then you need to talk to your employer. The FCC rules are very clear on who is permitted to add radios to an existing system. The license holder will have the correct programming info and likely has an existing radio shop that does their work.
As for programming, most Motorola radio shops can program these for you. Just make sure you have the license in hand, and approval from the licensee on agency letter head. Most reputable shops will not program radios for you on someone else's system without authorization from the license holder.
And the 700/800mHz bands are watched pretty closely. Programming random frequencies into those radios is unlikely to go unnoticed.
