Motorola XTS 3000 II VHF
FDRadioguy777
I have a model II XTS 3000. Does anyone know how to add a sidetone, in the CPS, so I know when the radio is keyed up? Also, the radio keeps rebooting saying SELF TEST at random times anyone know why that is? Thanks!
jhal94
Pinellas County, Florida
If you enable hardware encryption and leave it in clear it will make a beep sound when you key up (it wont beep if encryption is used though).
A real PTT sidetone option is in the MDC menu under MDC-System.
As for it rebooting it could be a million things such as:
The volume/power knob is loose on the internal contacts
The volume/power knob is bad
The battery is loose
The internal connector for the power contacts is bad or loose
The CPU is faulty and dumping its cache
The memory is dumping its cache
blah blah blah...
FDRadioguy777
Thank you very much for the information. I found out that it was just a loose battery. Also, thanks for providing the info on the sidetone.
sfd119
+1 for loose battery. Mine always did that and found it was the battery and nothing else.
hitechRadio
Use a Motorola original battery. I have had way to many problems with non-Motorola batteries. In the end you get what you pay for.
W0JJK
Also look at the contacts on the radio. Over time they wear down and have pits in them. I have seem this in both XTS3000 and XTS5000.
FDRadioguy777
I just got a new battery; That seems to have solved the problem. Thanks everyone for the help and the suggestions.
