Motorola xts 5000 programming questions
truckie27
Metropolis, IL
Having some trouble setting up scan lists on a selected channel. And about creating and assigning channel announcement files. I've got wav files created and tried using cps to compress/convert them but I get an error that no files are found in the directory. The help files were less than helpful on the channel announcement topic.
Sent from my Nexus 6P using Tapatalk
Are they .wav file extension, PCM format, 8k, 16bit, Mono, and less than (I think) 3 seconds long? Its very specific about the sample type.
ME801
NV
In personalities you need to set the scan list selection under the Scan tab. Under the Scan List in the tree view you need to open Scan List and select List and add your scan channels, I'm pretty sure Astro 25 CPS limits you to 16 channels per scan list, but you can make more than one List.
