Motorola XTS2500 programming cable.
dixie729
Daviess Co., KY
Does anybody know were I can get a genuine OEM Motorola programming cable for XTS2500?
I'm getting the error when trying to read it.
Sent from my XT1058 using Tapatalk
dixie729
Daviess Co., KY
Open radio failed.
Error context: 24, Status: c000039e
I figure its the cable
pepsima1
Banned
Pimp County, Neveda
I thought it was the 5000 that was disc? Make sure the cps has comm port 1 set and your pc is using com port 1 for the programming
dixie729
Daviess Co., KY
I would not spend the money on an OEM part since these units are dis-continued.
The knock off's work just fine. I have been using one for two years with no trouble. It could also be the comm port you are using. Try changing it in the CPS software on different ports to read and write the radio
Programming Cable for Motorola Astro XTS2500 XTS5000 MT1500 PR1500 XTS2250 Radio | eBay
I've got one for a 3000 and can read 3000's all day, but get that error on the 2500.
dixie729
Daviess Co., KY
Are the 3000's programming cables pin outs not the same as the 2500's?
rescue161
KE4FHH
Hubert, NC
No. The 3000 uses a different cable than the 2500/5000 series.
The 2500 has not been discontinued yet. I wish Motorola would have kept the 5000 and deep-sixed the 2500. I guess they make more in parts on the 2500. At least they do from us anyway.
The 3000 cable will work on ht1000s. Probably a few other older portables that are the ht series family. I don't recall exact other then the 3000 cable and the ht1000 use same cable. The xts2500 cable is same as the xts5000 and xts1500. I'm also agreed on the end of the 5k and figured the 2500 would go first. I always prefered the 5000 over a 2500 but both are good models.
sfd119
I've used the XTS2500 cable from KawaMall on Ebay without problems for years.
