Motorola xts2500 programming software
14torre
Florid
I don't know if this is the correct place for this but I am looking for some help with the Motorola xts2500 programming software. I have installed the software to my computer but when I attempt to open it a message comes up saying "can't find file specified". If any one knows how to fix this situation or can send me to the correct forum for this that would be greatly appreciated.
KevinC
Other
Home
I moved your question to its own thread where it will probably get more exposure.
jim202
New Orleans region
Well here comes the start of the questions if you want it to work.
What operating system is on the computer?
What is the computer, 32 bit or 64 bit?
Does it have a serial port or only USB ports?
Where did you obtain the Motorola software from?
If it is on an original Motorola CD, then uninstall it and try again.
If you acquired it from some other source then you just cut off all support.
MotoTRK
Even if you downloaded it from MOL you can uninstall and reinstall the software.
Jeremy
14torre
Florid
I have windows 7 64bit, it is a laptop so USB only, and I received it from a friend. If it is the case that he does not have the software directly from Motorola then I will just go ahead and get it my self and uninstall the one I have.
jhal94
Pinellas County, Florida
I assume you only have one hard drive and not 5 like me. If that's true then go here in computer:
C:\Program Files (x86)\Motorola\ASTRO 25 Products\ASTRO 25 Portable CPS
Once your there find the patport.exe file and run it. If it works then your shortcut is simply broken, so just right click on patport.exe and create new shortcut.
14torre
Florid
No that did not work. I may just get a copy for myself from Motorola before the radio is discontinued. Thanks for the help.
