Motorola XTS3000 CPS ID Display
radioman29505
I have an Motorola XTS3000 model III and I am trying to determine what I need to change in the CPS to display the unit's ID that is talking on a talkgroup on my display. Any suggestions?
DPapay
Morris County, N.J.
For MDC ID, you need to have MDC enabled in the signaling tab for each personality. Then in display and menu, advanced tab, enable talkgroup id on rx. That may work.
N4DES
The radio must have "Enhanced Caller ID" feature in the flashcode. If it doesn't then it won't work.
Also the XTS3000 will not cross reference the Call List to list an users name like it does in the 2500 and 5000.
immelmen
you must have H14 digital ID display in the flash, flashcode will start with a 4 or 5 if you have it.
in CPS go to radio config>displays and menus>PTT ID
check the box for PTT ID display.
radiomansc
XTS3000 Caller ID
I have a similar problem. I see radio IDs on a digital talkgroup but not on an analog talkgroup.
Any suggestions??
jthorpe
Any suggestions??
The only way to get that is by flashing the radio firmware and flash code. On the older versions, the analog ID display is not available.
