Motorola XTS3000 programming issues
gabrielpr12
I am trying to program some XTS3000 radios. I have the Astro 25 Tuner version R05.04.02 software and the RIBless cable from Motorola. I cannot read the radio. When I try using the COM1 port it will take a couple of seconds and say communication with the radio failed, if I use USB port, it automatically says communications with the radio failed. What am I doing wrong? Do I need a different software or cable? Thanks in advance.
W2NJS
Washington DC
You're trying to use the wrong CPS, that's all.
Astro Saber and XTS3000 use Astro CPS, not Astro 25. It's also preferable, to avoid trouble, to use an actual RIB, not a ribless cable, where RIB capability is required, and it is required when programming an Astro Saber or XTS3000.
Devilz311
NJ
Also, the Tuner Software is for adjusting the Tx/Rx settings in the radio, not programming. You need the CPS.
gabrielpr12
Can I use the Astro 25 Portable CPS? I also have that program and it won't read the radios? Do I need a driver for the cable?
LakebornNetwork
Commerical Operations
Northern Michigan
You need the ASTRO Saber & XTS 3000 CPS. The Astro 25 Portable CPS is for the XTS 5000 series (if my memory serves correct).
I am using CPS ver R5.03.00 for my XTS 3000 units. The 3000 units are no longer being sold by M so I think this is the newest version. They were discontinued, and replaced with the 5000 series and now the APX series. I love the 3000 series, they are a wonderful radio ...
As far as the cable, if you are using a RIBless unit connected to your COMM port, you do not need a driver. You just need to make sure you turn off the radio before connecting the cable. I have heard of problems when connecting the cable to a powered up radio.
But it has to be said that any programing has to be conducted professionally and to be in compliance with local, state, and federal communication laws and guidelines. The average "Joe" should not attempt to program a radio unless they are legally authorized to access a channel or system. There has been several discussions about the legality of turning a retired radio into a scanner. Yes that is legal, however, it is a waste since it's cheaper to buy a scanner. Further, the user / programmer has to be 100% clear that the radio MUST NOT TX at any time. It's too risky unless again you have permission to access a channel or system. Even the smallest TX on a public safety system or channel is VERY ILLEGAL (when not authorized).
