Motorola XTS3000 UHF FRS Programmed
Shane2016
Hello, I recently purchased a Motorola XTS3000 that I cannot access the menus on. I am able to transmit and hear the transmission on my Motorola Talkabout FRS radios. However I cannot hear anything from the XTS on my Talk About. So two issues here. What possibly is wrong and how can I correct this?
I bought it FRS conventenal programmed.
Thanks.
Sent from my LGUS997 using Tapatalk
krokus
Southeastern Michigan
Ignoring the illegal usage aspect, I am not certain if the XTS series is able to be programmed to transmit on the extra narrowband deviation that is used on FRS.
Easier and cheaper to use FRS radios for FRS. (Bonus of being legal, too.)
Sent using Tapatalk
mm
oregon
Seriously a 3K just for FRS use?
Yes the 3k will program fine on FRS freq's but why may I ask when there are better ways to do it?
The programmer Probably has RX CTCSS enabled on the XTS, hold in the monitor button (upper left purple button) on the XTS while TX'ING on the FRS radio.
But I have to really ask if this is a serious post and that you really purchased an xts3k for FRS use only?
This is like purchasing a sports car just to drive around a friggin golf course when a golf cart is a better choice.
I suggest getting a golf cart, uh I mean a 20 dollar FRS radio.
Skypilot007
Medford, NJ
I purchased an XTS3000 a while back and it was also programmed with FRS/GMRS channels. They all were simplex and had various PL and DCS tones programmed with them. It was engraved with Washington DC PD on the side of it. Perhaps you bought it from the same guy I did, he was selling many of them cheap. I quickly wiped the radio clean and reprogrammed for my needs.
If there is a button programmed for monitor mode press that and you should be able to hear your talk about. If the channels all have PL or DCS tones you're going to need to reprogram that to QSK or whatever tone you use with the talkabout radios.
XTS3000 is a bit over kill for FRS usage regardless of the legality of it.
KG7PBS
Sacramento CA
I seen them on EBay before good radio For FRS. They are using a PL I forget what one he used. And hope you get it working with the FRS Radios so you can use the XTS3000
