Motorola XTS5000 FPP Password
sam55671
Lyndhurst, NJ
Hello,
I have a XTS5000 with FPP and the radio does not want to set the FPP password. I keep putting in a new password but the radio does not save it and lets me get into the FPP without putting in the password. Anybody know what the issue might be?
mm
In the radios menu make sure a PSWD item is in the radios menu,
So Under DISPLAY&MENU place the PSWD item in the menu and place the FPP item in the menu list.
Passwords are only numeric.
The default numerical length of the password as I remember is 8 digits max,
for starters I would choose a numeric number that is 3 or 4 digits long and make sure this works.
In the ZONE CHANNEL ASSIGNMENT, under FPP/PROTECTION make sure that the PROTECTED ZONE box is checked for the zone/zones desired to be PSWD protected.
In RADIO WIDE, under ZONE PROTECTION ENTER in your 3 or 4 digit number password.
sam55671
Lyndhurst, NJ
Ok, I will try it if it does not work I will let you know.
sam55671
Lyndhurst, NJ
OK thank you it worked.
Do you by any chance know how to change your channel zone assignments from one spot to the other? I am try to place the channels in different orders and it wont let me.
rescue161
KE4FHH
Hubert, NC
You cannot change the FPP zones around. You can add new non-FPP zones to the end and place all or more of your channels in there. That's what I do with mine. I use the added zone(s) primarily and if I need to quickly add something, I'll change zones to an FPP zone and add it until I can get home and add it to the non-FPP zone(s).
sam55671
Lyndhurst, NJ
I tried in a non FPP zone but it does not seem to be working.
