Mototorbo RAS - Radioddity/Baofeng encryption
nated1992
Asheville NC
Mototorbo can utilize RAS on repeaters.
Comparing apples to oranges this looks similar to what Baofeng or Radioddity radios call encryption.
Has anyone tried or used these cheaper DMR radios set with "encryption" keys that match a repeaters RAS key and it worked?
alcahuete
Antelope Acres, California
No. RAS is RAS and encryption is encryption. They are two entirely different things. There is no radio besides Mototrbo that works with a RAS key, as the technology is proprietary. You will also not find Baofeng or Radioddity encryption that works with any other brand.
The only Cheap Chinese Radio with encryption that is compatible with any other brand is the Anytone 878/578. It has AES-256 encryption.
nated1992
Asheville NC
Have you tried it? Looking for real world implementation and success or failure
alcahuete
Does the anytime 878 work with RAS?
As @N1GAW and the rest of us have said, RAS is proprietary to Motorola. There is no other radio that will work with RAS besides Mototrbo radios.
Certain radios and scanners will ignore the RAS frame and allow you to listen to RAS systems, but you will absolutely in no way, shape, or form be able to transmit on a system that utilizes RAS keys.
nated1992
Asheville NC
Sorry that asking a simple question is so offensive. The only way to gain knowledge is to ask questions. No need to be rude! But then again most people are jerks why would here be any different
