Mototrbo CPS 2.0 ???
lion2479
Hello, currently have Mototrbo CPS Version 16 (868) on the laptop. Need to install the latest CPS version 2.0 on the same laptop, if I download it to this machine will it overwrite the older version which is currently needed for the current portables that were programmed with the older version 16? Can someone advise how to put two separate versions of the CPS on the laptop if even possible with step by step instructions. I would hate to loose the ability to use the older CPS after I download the newer version 2.0 onto this working laptop. Any advise or assistance would be appreciated, don't want to go purchase another laptop just to have a newer version of this CPS. Thanks in advance.
lion2479
CPS R16 and 2.0 can be installed concurrently with no modifications. Just run the CPS 2.0 installer and it'll install as a separate program, keeping R16 intact.
Thank you for your quick reply. Much appreciated.
n3obl
Ø
PA
No Bluetooth was dropped in cups 2.0. You would have to stick to cps 16
sammyg512
Nope, both are completely seperate software applications, so they can both be installed at the same time. I have both installed on my laptop.
plod11
Looking for cps to program dp3441e, i have cps 16 but it seems to need something newer 2.0? I thought it would program with 16, but it says code plug not supported.Been trying to access 2.0 via my view on the motorola site with no luck.
Reconrider
Inside the Galaxy
Radio Galaxy
If you googled, you'd have known you would need cps 2.0 if it's over a certain firmware.
You can get 2.0 by using HKVN4362A as the product key in the search on the moto software website.
No, no body can give you the software on RR, it's against the rules
plod11
Thanks for that, not looking for anyone to give it to me. I can see dp3441 in the sample files on cps16, no idea what firmware it has, but appears to be newer than the cps 16, been trying to get 2.0 but not getting anywhere down loading it from moto software site, just get "oops something went wrong" will keep trying but loosing the will now.
Thanks anyway
Reconrider
Inside the Galaxy
Radio Galaxy
Thanks anyway
Moto Software
make sure you're on "Software Download"
Product Line = MOTOTRBO
Search Box = CPS
Sort by date released and get the most current. it should be Sept 5th
Click the 3 dots and "download".
Will bring you to another page that you can download
plod11
Moto Software
Search Box = CPS
Still no joy with the CPS , got given this DP3441 at our local club. I know why no one wanted it now. Only want to put some DMR channels in it for my local Amateur DMR repeater and my Hotspot.
Think i will shove it on e bay, Thanks for your help anyway :)
