Mototrbo CPS issues
N1SQB
Somewhere On Earth
I am installing Mototrbo CPS V 14.0 Build 717 on my Panasonic toughbook laptop running XP 32 bit. Once the install is complete and I click on the icon, I get this error:
C:\Program Files\Motorola\MOTOTRBO CPS\mototrbocps.exe is not a validWin32 application
What exactly is this about?
Manny
N1SQB
Somewhere On Earth
I have version 10 on XP now, this is an upgrade, so I guess I need to switch over to Win 7 then.
Thank you both for your replies.
Manny
N1GTL
CT
Manny
TRBO definitely not supported on anything less than Win7. Also, Build 717 is no good. Motorola released build 738 about a week after 717 came out. Download the newest CPS.
rbrtklamp2
Dupage County, Illinois
Manny
Unfortunately a few releases ago Motorola stopped supporting Windows XP and Vista. Happened to me with the apx software too. So you will need windows 7 or above to run the latest CPS from moto for pretty much any current line od radios they are still releasing CPS for.
Sent from my SM-N910V using Tapatalk
PACNWDude
I ran into this a while back with my older Panasonic CF-72 running WinXP x32 as well. So now it is a dedicated older radio programming computer. R10 Trbo CPS and earlier are on the Panasonic. R11 CPS and newer is on the Itronix x64 Win7 laptop.
APX does need Win7 or newer as well. Good info, and so I now label each laptop on which radios I can program with them. A very old Toshiba is for RSS DOS radio programming. I use semi rugged computers mostly as they still come with serial ports.
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
Anything over Version 11 won't work on XP, have to have at least 7 or 8 for that.
Regards,
-Frank C.
radioguy99
Salt Lake City
MotoTrbo 10.8 is the last for XP
Motorola stopped CPS support after 10.8. Anything before that, your fine. The newest version released is 15.0 and you must have Win 7 or higher.
