MotoTrbo RAS
zsauve
Oak Creek, WI
I am planning on turning on the RAS functionality on my capacity plus system. We have 1 main site that is transmit and receive and another site that is strictly satellite receivers. Do i only have to enable RAS in the master repeater or do I need to enable it for the receivers too.
musan
BiH
Only to the master. However when you enable RAS key into master repeater you will not be able to enter another RAS in satellite ot slave repeater,because CPS will not allow that function.
Master repeater key order same key on all connected repeater.
Sent from my HUAWEI SCL-L21 using Tapatalk
N1GTL
CT
Master. Set it to"migration" mode. Re program all subscribers then change migration to "enabled" after all subscribers are reprogrammed with your RAS key.
