MotoTRBO XPR5550e with PMLN7131 Kit Handheld Control Head
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
Is there a minimum firmware needed for the XPR5550e to run the PMLN7131 Kit Handheld Control Head?
Is it just plug and play?
I program the 5550e through the front mic port using either CPS 16 or 2.0.
I will be attempting to run my XTL5000 and XPR5550e mobile with handheld control heads O3 and PMLN7131 respectively.
Jim
KO9JAD
MTS2000des
5B2_BEE00 Czar
It's supposed to be plug and play...however, firmware mismatches between the CH and radio brick may give you the annoying "red LED blink" in which case you'll need to do a recovery in CPS to resolve. What firmware does your 5550e run now?
