ke4zdj
Im looking at possibly putting a 2 meter antenna on top of the mountain peak behind my house. This will require about 1000' of line. Any suggestions on what to use? Thanks
Is there power at the top?
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9780; en-US) AppleWebKit/534.8+ (KHTML, like Gecko) Version/6.0.0.600 Mobile Safari/534.8+)
Sinclair Radio Labs 210-C4 or the equivilant BlueWave antenna.
prcguy said:Why do you recommend that model?
prcguy
kayn1n32008 said:Sinclair Radio Labs 210-C4 or the equivilant BlueWave antenna.
Well made. (will out last ANY fibre glass vertical)
DC grounded.
Fairly omni pattern depending on configuration. (210-A4 has external cabling and clamps so the spacing can be changed)
Stackable.
VERY broadband with gain. (6Dbd for a 4bay)
Also Resonant from about 400-450MHz,(verified with a Anritsu site master) probably wider, but only interested in 430-450MHz. This allows us to diplex a link radio or a Uhf repeater on a single feedline.
All welded, and internal cabling. (210-A4 is external cabling) It WILL survive THE most extreme winter conditions.
This antenna and its little brother the 210-C2 ARE the more popular repeater/base used where I live, I have seen deformed aluminium verticals and the mounts of former fibre glass verticals but the C-4 stays true.
Myself and some others are installing Vhf repeaters with diplexed Uhf links into sites that have 30+ year old 210-A2s leftover from a 20+year defunct radio system. We have yet to see an antenna that has failed, only damaged hard line.
