Mounting Bracket Knobs for pro-2096
mike6454
Eagan,MN
Anybody know where i can get 2 black plastic knobs that come with the pro-2096 black mounting bracket that screw into the sides of this radio?
Mine got lost,
been looking all over the world!Anyone know the size of the screw in part i could maybe order
a couple small bolts from homedepot.com and improvise?
Thank you to anyone with knowledge from Mpls.,MN
2-BC996T
BC795D
Pro-2096
Pro-96
myhdsport
is it pro-96 hand-held
or pro 2096? I have a junked handheld, but since I recently moved-it may take some time to find it. Let me know, I'll look around. Have you tried other knobs? IIRC, they seem to have been fairly common.
SLWilson
Ohio
Radio Shack?
Have you called your local Radio Shack? Your manual has a part number listed for those....
Steve/KB8FAR :D
mike6454
Eagan,MN
Re:Knobs
yes,my local Radioshack is just as lost as i am on buying these.
I looked in my owners manual-cannot find a part number,
anyone know the correct bolt size on these??
pro92b
Mutated Member
The bolts are M5 metric. Hardware for the PRO-2055 is probably the same and the mounting kit is available as part number 12429197 MOUNTING KIT $11.29. It includes washers, rubber feet and DIN keys. You can take a chance and order the PRO-2055 hardware or maybe someone who works for Radio Shack can post here if the kit is compatible.
iMONITOR
Silent Key
S.E. Michigan
No, your local RadioShack is not lost, they're being lazy and just don't want to take the time, or make the effort to help you. All RadioShack personnel are trained on how to look-up parts and order them. This is just another example of why they're slowing going out of business. :roll:
Click here:
http://www.radioshack.com/helpdesk/index.jsp?display=store&subdisplay=contact&stillHaveQuestion=yes&clickid=footer_contact_txt
mike6454
Eagan,MN
Found Knobs for pro-2096
Success!
I found 2 knobs for my pro-2096 mounting bracket
Walcottcb.com
2-$1.95 plus shipping
enine
I was going to say, I think they are the same as CB threads. So you could stop ata flying J or someother truck stop/travel center and pick them up.
