Mounting laptop and radio in hard case
pb_lonny
Tasmania
I am planning on mounting a small laptop and two handheld scanners in a hard case for portable usage. I have a rough plan but am having trouble finding the best way to mount the laptop to the case so that it is:
- usable in the case
- stable and secure.
- removable if required.
My plan it is cut a piece of MDF to the same size as the inside of the case and mount them to this, any ideas or suggestions?
W5SAB
How small of a laptop, because some adhesive velcro strips would probably work. Specifically 3M dual lock.
Below is a YouTube clip of the stuff
https://youtu.be/028f8k1lXi0
I have used them in part of the construction of ham radio field box and they work great.
Though about possibly using a raspberry pi for your project. It would probably allow you to shrink the case. Its low power, there is a 7 inch touch screen for it
pb_lonny
Tasmania
It is a 10 inch netbook. I already have this and the case, just looking at ideas to mount it.
W5SAB
Nice, still have a 10 net book myself that i use for field radio events.
3M dual lock will definitely work then
Sent from my iPod touch using Tapatalk
W5SAB
have power source figured out?
here's how i built a simple powerpole 12 volt Power supply adapter for my netbook. it as adjustable voltage output quick, easy, snd got the parts from Amazon inexpensively.
Sent from my XT1585 using Tapatalk
