niceguy71
this hobby is not easy... I just thought I would hook up my base and my mobile and see how I get out and how far and chit chat a little.... the base antenna I'll deal with another day... hot HUMID summer this year with thousands of horse flies... so I still have to crawl under the truck and put 1 1/4 inch RF straps to the cab and body and to the cab body hood to frame and also some ground wires... but I'll put the antenna up and see how it does.... not too good 1.8swr on channel 40 ..........2.0swr on channel 20 and 2.2swr on channel 01 ... but I can drive in and out of the garage... 6 inches clearance... see picture... that poor antenna and my roof won't take too much of that... so now I'll mount the cb... I bought a floor mount that bends in all directions.. pretty nifty... $50 .... well it was not wide enough for my monster of a CB so I cut it in half.... then I could not bolt my CB into it as my CB is 11 inches long and it bottoms out.... I tried to put it in the truck but it would cover my cubby hole and it would make it so my slide out cup holder would not be able to slide out.... see pictures.... so I bought a workman transmission CB mount with cup holders and speaker... $50 looks really nice... I jammed it in place and it fit ( tight) see pictures.... but the CB mounts on the end of it and it is jammed up against the dash board... so that's out! ... then I thought if I mount it to the pull out cup holders it may just work... so I sent to a junk yard for one like I have in my truck $50....... I put wood in it and bought some metal brackets $50 ( screws metal and wood) looks like it may work.... when I use it I slide it out.... and the cup holders still work... when I need to get to my cubby hole I can slide it in and have access..... ,,, not really sure it will work as my problem is I can't get the old one out!!! I worked for 3 hours in the hot humid garage trying to get the old one out... I will run over to a Ford body shop and see if they can figure it out.... but I may have to take the seats out... does everyone run into this trouble or do the CB Gods just hate me????
