It just looks more complicated than Win500 so far. Example: setting alerts, Win500 has a drop down box showing the different colors, audio beeps and flash for each object or group. It seems that a series of alpha/numeric codes are needed for EZ Scan and I haven't found a definition of which codes match which colors, flash, etc. Thanks for your reply. I did use the card reader to update the SD card as I could not get it to work thru the scanner. Whole experience just seems more complicated, ( remove faceplate, SD card, update in PC, archive, load back in scanner, reattach control head, load objects) compared to just plugging in the programming cable and either "send to scanner" or "receive from scanner" with Win500. As well as the insert, copy, paste features similar to MS Word that can be used in Win500 and just a simple "save of save as" rather than archive. Just getting old and resistant to new tech I guess. Thanks again.
OK, I think I'm getting the hang of using EZ scan. I've got all my data in, (261 objects) using the card reader on my PC. Installed it back in the scanner, connected it to the PC by USB and updated the CPU and DSP,
turned it on and it went thru several bars of verifying. I pressed the right arrow to scan, it beeped and said NOTHING TO SCAN!
I removed and re-inserted the sad card multiple times and still NOTHING TO SCAN!
Any idea why it isn't finding the programed data? I am at a loss at this point.
Got my WS1098 alert lights set up for every object and they worked for awhile then stopped. Scanner still receives and screen displays object information like normal but no alert light. Has anyone else had this problem?
