MPSCS TG Correction?
firephotographer50
Port Huron, MI
Hey Everyone. I've just been listening to the Marysville Fire Department (St. Clair Co) doing radio checks on various TG and on TG 2727 which is listed in the database as PHFD Dispatch channel 676F911 they were saying "Marysville FD testing on 74 F 13...test 1..2..3". Also for the past few weeks Port Huron Fire Department has been running all calls on TG 12153 which is listed as 676FG1, but the guys on the department tell me they run mainly on 676F911. I've heard from different sources that the techs have been reprogramming the radios lately. Could they have switched some of the Alpha tags in the process, or is there something else going on that I haven't figured out yet? Thanks for any help.
bigbluemsp
Michigan
They are retagging tg's.
At least that was what Rob & Dave said the other day when I had lunch with then (Radio Guys for PH).
It's not offically changed as of yet thats why I hadn't submitted them to Ron yet.
Ill have to hook up Pro96Com and get an offical comfirmation on that.
firephotographer50
Port Huron, MI
Ok, that explains some things. Could you also check on 562COM (TG 2728) which is listed as Marysville Common. Last night I heard the FD call back to base and say "Marysville Engine 1 on Primary". Do you know if they're retagging them all for the county or just certain ones?
Thanks in advance, bigblue, and I'll give you a Tx when I get a chance.
rdale
Lansing, MI
Pro96Com doesn't show the alpha tags, so if you have better info go ahead and submit that.
