I just purchased a bearcat MR 8100 on ebay. Any tips on programming and using this scanner.
B bryank104 Member Premium Subscriber Joined Apr 9, 2014 Messages 104 Location hudson falls ny Aug 10, 2017 #1 I just purchased a bearcat MR 8100 on ebay. Any tips on programming and using this scanner.
Paco-Jerte You Member, Member! Joined Nov 28, 2007 Messages 556 Location 34.0500° N, 118.2500° W Aug 10, 2017 #2 You might wanna look here, but I believe you have to register to access the link https://www.mods.dk/downloadmanual.php?RefFil=MR8100_manual_and_other_stuff.zip and also here http://www.gfcsoftware.com/
B bryank104 Member Premium Subscriber Joined Apr 9, 2014 Messages 104 Location hudson falls ny Aug 11, 2017 #3 Thank you ill try this software and see if it will work
E Eugene Member Joined Dec 19, 2002 Messages 586 Location Portsmouth, VA Aug 16, 2017 #4 I had one......Needed a floppy disc to program it. The problem with it....I found....is in an area with high RFI (pagers in particular) it is only a double conversion scanner and will pick up lots and lots of intermod......good luck. Eugene KG4AVE
Linneweh Member Premium Subscriber Joined May 13, 2005 Messages 31 Location Elmhurst, Il Aug 16, 2017 #5 Owners Manual here; https://www.manualslib.com/manual/888020/Uniden-Mr-8100.html
