I just got a Uniden MR8100 that I'd like to program with my local frequencies and the alphanumerics to go along with them. The problem I'm running into is that every time I attempt to program the scanner using the Uniden SCAN.EXE program, the process stops at the third channel in the first bank. It just hangs there forever, and essentially hangs up the comm port, as well. When I check the scanner (after resetting power), the bank name for the first bank is programmed, as are the first two channels. Nothing else.
Does anybody have any idea what might be going on?
FWIW, I'm running Windows XP Pro as a guest operating system under VMWare Player on a Windows 7 Pro machine.
Thanks,
Greg
Thanks,
Greg
