ms119 super scanner antenna
Mike248
Waterbury
Looking for relay box or where I may buy internal parts[relays]..Your info. will be greatly appreciated..
JayMojave
Mojave Ca
It appears that there two versions of relay box's one 120 VAC and one for 220 VAC, but it looks like the relays are 12 volt 2 pole, DPDT relays. The diagram shows a 24 VAC transformer running the scanner but thru a resistor to drop the voltage to run the relays and lights. See:
