MSP TG 40128
tomwilliams134
Athol, MA
I've been occasionally picking up TG 40128 on the MSP trunk system. It's not currently in RR. It seems to be a mutual aid but I haven't been able to pin it down. I've also got logs of UID 65520 on this TG, which also shows up on LPS-10 (TG 36624) and WMLEC PD (TG 40208) and Greenfield PD (TG 41264).
Anyone have any insight, and if you do, it would be great to get this ran as an update to RR.
Thanks!
cg
Connecticut
On a Motorola Type II, 65520 is a common RID for a patch to an outside system. All 65520 traffic in not necessarily from the same radio.
nikronzo
65520 is the ID you see when a SmartX converter translates a Astro core digital ID to a legacy system. The hard limit for a Smartzone 4.x core is in the 65000s so when you have digital IDs from the newer 7.x system that won't translate to a patched channel, you in turn see 65520 as the ID showing up on analog.
