MT1000 / P200 Programming ... anyone?
sefrischling
Public Information Officer
New London, CT
Anyone know a shop or person that is currently programming MT1000 / P200 low band radios?
I have four 33mhz radios that need the six channel radio plan updated. Yes, some fire departments are still on 33mhz. Trying to make all the radios the same to make life easier, but our three local shops can no longer program the radios.
GearJammersc
SC
Probably not not that hard to program. The software available online just need the cable that's available on ebay cheap. Only problem is you will need a old computer like a 486 with MS-DOS
impalass427
Connecicut
I can do it. I'm near New Haven. I seem to remember that you needed some to be programmed a couple of years ago too. Don S
sefrischling
New London, CT
I had a few programmed for a different department a while back. That shop no longer programs the MT1000/P200. The town got rid of their low band portables, so I picked up a few for the company I am a member of. Now I am mostly at the department next door, and have found myself handed the task of building out the radio plan for the new tanker, to address VHF and UHF ... and what a shock ... the common channels are primarily cross banding of 33mhz. So I am back to trying to get a few low band portables reprogrammed.
Presently I have one MT1000 and three P200 portables. If you are able to program them let me know how much and if its easier to mail them to you or drop them off.
Thanks.
petnrdx
Hudson, FL
I can also program them and align if you need. $70 bucks to program align and resolder. I would pay the for the return shipping
in USPS flat rate box.
But they would have to be mailed to Nevada. Radios only don't need the batteries.
Whoever you have work on them, please resolder the antenna connection and the connections from the circuit board to the
accessory connector.
I have worked on maybe a thousand of those and nearly all need those connectors resoldered.
Simple job, takes five minutes and pretty much anyone can resolder those.
Users handle the radios by the antenna and that breaks the solder and you get intermittent TX and RX.
sefrischling
New London, CT
Thanks folks, I just packed the four radios up and shipped them off to someone who can amazingly program them in the region.
