MT2000 UHF OOB Problem
PSNY
I have a UHF MT2000 in the 450-520 split that I was expecting to work out of band the same way I've done with my HT1000 using the SHIFT key method. It unfortunately has not been the case, is there a workaround for this other than modifying the ODB file ? I have to suspect that because the SHIFT key works for some users and not others, it is probably dependent on the version of .rss being used ?? Thanks in advance
PSNY
Disregard the post. I have found out that the Shift method is most likely not applicable to MTSX rss but I was fortunate enough to get a modded ODB file that takes me out of band where I want to go. Keep your original ODB file in a safe space to refer to later if need be
