MT500 no transmit audio
knockoffham
Michigan, USA
I have a high VHF MT500 that has basically no transmit deviation. I don’t have a service monitor for it so I’ve been testing by just transmitting and talking into it with a nearby receiver. There is basically no deviation unless I turn it up all the way on R211/R212 (the only thing to do with transmit deviation I could find in the service manual) and even then it is barely audible. The carrier it puts out is nice and clean, and it also receives fine. I have swapped out the microphone in the radio to no avail. Are there other adjustments? I don’t know if the PL deviates/transmits properly, this is a DPL model it seems like and I don’t know the code. I suspect that there’s a dead microphone preamp somewhere, any tips on how to replace that and where it is? I may seem dumb, this is my first time with a crystal controlled former part 90 HT. Thanks.
knockoffham
Michigan, USA
Speaker mic works fine. So I might have 2 bad mic elements? Does the speaker mic follow the same path electrically as the internal mic element or are there some other components along the way that could be giving me trouble?
N4DES
Retired 0598 Czar ÆS Ø
South FL
It's been a very long time since I have worked on one, but I recall the side block had both mechanical switches for both RF and audio for use in the ConvertaCom. You might want to consider that as well being the speaker mic worked but the internal mic doesn't.
knockoffham
Michigan, USA
Ok. I will check that out. The internal mic does work, but at a basically 0% audio level. The only way I can hear anything is tapping on it. Thanks!
